Цельноточенный блок 2JZ-GTE, Для 1500HP+
сообщение 12.1.2014, 16:19
Racing experience has shown that the stock iron block usually only last up to 2000hp. It then splits vertically along the head studs. We have also seen the main caps get loose. To resolve this, we designed this billet block. This block is completely made in house at Mazworx.
It features the following:
- Made from 6061-T6 Aluminum
- Deck height can be raised up to +.400"
- Uses 1/2" Head Studs and Main Studs
- Tunnel will clear a 94mm stroke with aluminum rods
- Connection between the head stud and main stud stronger
- No water jackets keep the cylinder rounder
- -12an main Oil Inlet
- Single Turbo Oil Feed
- Main Caps are either 7075-T6 Aluminum or 4340 Chrome-moly
- 4 Bolt Mains on caps 2, 3, 4, 5, 6
- Caps can be individually taken out for easier maintenance at the track
- Uses Darton Sleeves already installed, bored/honed.
We recommend using the aluminum main caps. They are taller to handle the load and absorb impact better. If you plan to use a thin oil pan such as the OEM one, the go with the chrome-moly caps. They are small just like the OEM ones.
The block comes ready to assemble with the main caps and main stud kit.
Weight of block with aluminum caps and studs is 85 lbs.
Вес 38.6 кг
- John_Travolta   Цельноточенный блок 2JZ-GTE   12.1.2014, 16:19
- - drool   Красота Вот еще контора аналогичная http://www.bu...   12.1.2014, 17:34
- - Wolf_sw   - No water jackets keep the cylinder rounder и ка...   12.1.2014, 20:26
- - John_Travolta   DRAG Only   12.1.2014, 21:17
- - beast_drc   и стоимость тыщ 10 баксов только за блок ?)   12.1.2014, 22:13
- - Wolf_sw   не вижу смысла ради 1500 .... люблю 2JZ но в этой...   12.1.2014, 22:38
- - Блек   Как я понял из описания охлаждение только масленно...   12.1.2014, 23:41
- - beast_drc   Вы меня парни простите, но вы уже наверное по 10 1...   13.1.2014, 7:17
|- - Wolf_sw   Цитата(beast_drc @ 13.1.2014, 9:21) Вы ме...   13.1.2014, 11:01
- - John_Travolta   Чугунные блоки заливают цементом, там тоже нет охл...   13.1.2014, 9:41
- - Блек   John_Travolta, экономия в весе более 20 кг. Я его ...   13.1.2014, 10:18
- - John_Travolta   Блок в сборе (колено 30Кг + поршни и шатуны ~ 5Кг)...   13.1.2014, 10:23
- - John_Travolta   Цель только одна- максимльно возможная мощность. Н...   13.1.2014, 11:15
- - Wolf_sw   не спорю очень дорогая экзотика.   13.1.2014, 11:18
- - beast_drc   Wolf_sw, логика тут простая. если спортсмены этим ...   13.1.2014, 13:08
- - Wolf_sw   весч конечно для драга сама по себе крутая. но это...   13.1.2014, 13:44
- - 316   В описании сказано, что родной блок кончается на 2...   13.1.2014, 14:35
- - Sub   Цитата(John_Travolta @ 12.1.2014, 18:23) ...   13.1.2014, 16:00
- - Блек   Вес сток блока без бугелей и задней крышечки, но с...   4.6.2014, 22:45
RSS Текстовая версия Сейчас: 27.11.2025, 19:42
