Цельноточенный блок 2JZ-GTE, Для 1500HP+ |
Интересная штука
![]() ![]() Racing experience has shown that the stock iron block usually only last up to 2000hp. It then splits vertically along the head studs. We have also seen the main caps get loose. To resolve this, we designed this billet block. This block is completely made in house at Mazworx. It features the following: - Made from 6061-T6 Aluminum - Deck height can be raised up to +.400" - Uses 1/2" Head Studs and Main Studs - Tunnel will clear a 94mm stroke with aluminum rods - Connection between the head stud and main stud stronger - No water jackets keep the cylinder rounder - -12an main Oil Inlet - Single Turbo Oil Feed - Main Caps are either 7075-T6 Aluminum or 4340 Chrome-moly - 4 Bolt Mains on caps 2, 3, 4, 5, 6 - Caps can be individually taken out for easier maintenance at the track - Uses Darton Sleeves already installed, bored/honed. We recommend using the aluminum main caps. They are taller to handle the load and absorb impact better. If you plan to use a thin oil pan such as the OEM one, the go with the chrome-moly caps. They are small just like the OEM ones. The block comes ready to assemble with the main caps and main stud kit. Weight of block with aluminum caps and studs is 85 lbs. Вес 38.6 кг -------------------- |
Текстовая версия | Сейчас: 13.10.2025, 10:54 |
