Отсечка по бусту отключена сразу, так как это очень просто )) (на VVT-i отключается снятием шланчика с MAP!)
Дело не в катушках и проводах, так как первые 1 до 3 тыс. км все норм, тачка валит, ровный разгон, все ок! С буст-ап компом даже до 1,6 в пиках прыгал буст по зиме (-20С) и не было провалов... Вопрос теперь в том, где взять свечи с маленьким зазором... В основном 0,9, 1 и 1,1!
Нашел....Выжимка:
АтмоNGK - Standard - BKR5ES-11 (2382) - gap is already 1.1mm at the "-11" signifies they should be set to this already.
NGK - V-Power - BKR5EYA-11 (2526) - gap is already 1.1mm at the "-11" signifies they should be set to this already.
NGK - G-Power Platinum - BKR5EGP (7090) - gap to 1.1mm
NGK -Laser Platinum - BKR5EP-11 (3440) - gap is already 1.1mm at the "-11" signifies they should be set to this already.
NGK -OE Laser Iridium - IFR5T11 (4996) - gap is already 1.1mm at the "-11" signifies they should be set to this already.
NGK - Iridium IX - BKR5EIX-11 (5464) - gap is already 1.1mm at the "-11" signifies they should be set to this already.
Denso Platinum - PK16R11 - gap to 1.1 (but always check first)
Стоковая TTNGK - BCPR6EP-11 - gap is already 1.1mm at the "-11" signifies they should be set to this already.
NGK - BKR6E (2756) - gap 1.1mm
NGK Iridium - BKR6EIX-11 (3764) - gap is already 1.1mm at the "-11" signifies they should be set to this already.
Denso Platinum - PK20R11 - gap 1.1mm
Denso Iridium - IK20 - leave gap alone
TT @ до 1barNGK - BCPR7ES (3330) - gap 0.9mm
NGK - BKR7E (6097) - gap 0.9mm
NGK - Iridium - BKR6EIX or BKR7EIX - leave gap alone
Denso Platinum - PK20R11 - gap 0.8mm
Denso Iridium - IK22 - leave gap alone
TT/hybrids @ до 1.3barNGK - BCPR7ES (3330) - gap 0.7mm
NGK - BKR7E (6097) - gap 0.7mm
NGK - BKR8E - gap to 0.7mm
NGK - BCPR8ES (3330) - gap 0.7mm
NGK Iridium - BKR7EIX - leave gap alone
NGK Iridium - BKR8EIX - leave gap alone
Denso Platinum - PK20R8 - gap 0.7mm
Denso Iridium - IK24 - leave gap alone
Single Turbo/Big Twins @ до 1.3barNGK - BCPR7ES (3330) - gap 0.7mm
NGK Iridium - BKR7EIX/BKR8EIX - leave gap alone
Single Turbo/Big Twins @ до 1.8barNGK - BCPR8ES - gap 0.6-0.7mm
NGK - BKR8E - gap 0.6-0.7mm
Denso Iridium - IK27 - leave gap alone
Single Turbo/Big Twins @ 2+barNGK - BCPR8ES
NGK - BKR8E
NGK Iridium - BKR8EIX or BKR9EIX
Denso Iridium - IK27 to IK31
